1 - 2 of 2 Posts
Hello I'm new to the G20 community and I just have a question, I've replaced the other motor mounts except for the automatic transmission mount because of the metal bracket that's in the way of the two screws. How do you remove those two screws to remove the automatic transmission mount? I've tried using a socket and there just doesn't seem to be enough room to move around
Thank you
The long bolt that goes through the mount has to come out and the drivetrain has to be lowered to get the 4 bolts and mount out. It is best to disconnect the radiator hoses so you don't flex and crack the radiator when moving the engine around.
1 - 2 of 2 Posts
