Hey guys, Can anyone tell me where the Rev senor plug is connected in my p10, Have a few theories I need to do and it involves disconnecting that sensor, Where is it located?
Is your tachometer jumping around? this is common on G20 when the tach is going bad, that means you'll have to replace it. as far as where it's located it is right behind the tranny you should see it right in front of the lower control arm on the transmission... according to the 94 fsm
not a tach problem
Car is actually stuck in First gear, Ive done lots of reasearch and it seems as if its an electrical problem and nothing mechanical or inside the transmission.
