1 - 17 of 17 Posts
i was wonderin if anyone has had any problems with changing rims sizes from 15 in the p10 to 17 aftermarket like the tire scrubbing the wheel walls. and should i change the struts and springs on my car before i put rims on my car:evil:
You're not going to have any problem going up to 17" wheels as long as you get a lower profile tire (205-40-17) You don't have to lower the car with the new wheels but it will definatally make a big difference in the looks of the car. I'd lower about 1.25-1.7 depending on your preference.
Jim
Actually, your stock wheels should be 14" wheels. With the proper offset, and the correct size tire you could fit 17's lowered, or not lowered, it shouldn't matter. Quite a few people have 17's on their car, I believe most are running a 205-40-17, i've heard of a couple 215s, but i think you may have issues with that wide of a tire.
I just put on some enkie 17s and my passenger side rear rubs like a *^%$#. I had to go with 215/40 because the 205/40 left a lot of space between the edge of the rim and the tire. I may just need new shocks though.
Ultra light weight rims
I personally like bigger rims for a look; however, they make the car to launch slow. I have 15 inch rims right now and I love them. If you choose 17 inch rims, get the ultra light weight rims such as Axis Se7en or Volk Racing TE or LE 37s.
imho...
The 17's are a bit of overkill not to mention the fact that you'd have to become a pot-hole expert on your local roads!! The 16's look great and if you get a set that gives you a slightly wider tire your handling performance will be greatly improved! To occomodate the wider tire you should go with a slightly smaller diameter. In my case I went from a 195-65-14 (stock) to a 205-45-16 (bout .8" smaller diameter than stock) vs. 205-50-16 (bout the same diameter as stock). The difference means bout 3% error in speedo and odo but the "no rub" insurance and handling makes it all worth while.... G20's have awsome cornering abilities with the right set up....
peas. :crosseyed
I feel you bro:-\. Ever since I put 205/55R15s on mine, they been rubbing over even the slightest bump. I hope that someone at the Texas Rally on April 20 will be able to figure out what's wrong. I'll email you and tell you what they find.
Mr-ryte....
Those 205/55/15's are wider than stock.... you should have gone with 205/50/15's (slightly smaller diameter) should keep the clearance in check... essentially you have the same diameter tire but the 205's add .5-.7" width (rubbage source I'm guessing)
Re: Mr-ryte....
Actually, the 205/55/15's are smaller in diameter than stock. And only the front passenger side rubs. I'm not too well knowlegded on suspension parts but I believe that it's more of an issue of a bent/worn suspension part than just a tire issue. The reason I feel that way is because the upper links have been changed on the car and not the lower links/control arms. When I take it to most of the shops, they just shrug and say"Maybe you need new shocks.":-\
re:Actually, the 205/55/15's are smaller in diameter than stock.
.1" smaller... thats a whopping 2.5 millimeters... I still say the width of the 205 is your problem, you have added bout .5" in WIDTH from stock - where do you expect that extra half inch to go?? Get 205/50/15's..... bit smaller in diameter to occomodate the extra half inch in width.
Re: re:Actually, the 205/55/15's are smaller in diameter than stock.
:depressed MAJOR BUMMER :depressed . I may have to do that if all else fails. But it still rubbed when I had 195/60-15's for a real brief time. Not as much, but enough to notice. :-\
195/60/15's adds .25" in diameter.... Same width tho... It doesn't seem like much but it shows how the design of the wheel well fits the tire/wheel like a glove... It's all kinda simple... If you ADD a bit of width then you have to subtract a bit of diameter / If you add diameter then you'll have to subtract width (bad for performance, good for fuel economy in this case :crosseyed )
That's why I'm telling you... 205/50/15's or 205/45/16's (for 16" rims) or 205/40/17's (for 17" rims) OR 205/35/18's (for 18" rims)
Anyone dissagree?? These tires are bout .5" wider and bout .5" smaller (in diameter to avoid rubbin') In my opinion once you get below a 45% profile (40,35,30!?!) your in pothole trouble land!!
I think that the guys who are having problems with tires rubbing has very little to do with the size/width of the tire and much more to do with the offset of the wheels you bought. If you get too much positive or negative offset, your tires will rub.
1 - 17 of 17 Posts
