1 - 10 of 10 Posts
Question. I have 225/40/18 tires on my 18's. When i ever i do a full turn, my tires are rubbing in the front. What can i do to stop this, will spacers solve the problem, if so what size and where do i get them. I have an 02 p11 Sport. :zoinks:
what offset are your rims??? hopefully 42-45mm... if your between 40-42mm, try a 215/40/18. if that still rubs, a 215/35/18 might take care of it.
im running 215/40/18 18x7.5 42mm on stock suspension no chance of rubbing
have the same size on my car am sure you get jus a littlle rub ,no big deal maan dont think you gonna want 35 series though, the ride is very stiff and good luck to you with pot holes if you do get them anyhow if i were i would jus leave it and probably try 215/18 40 next time
I dont remember the offset of the rims, but they are 18x8.5, 2inch lip. I dont think i want to buy new tires because these are new, so i guess i'll just run with these until its time to change, but thanks for the info everyone. These 225's grip and handle the road very well, i love them, but i hate the rubbing when i do a full turn.
NismoG20T said:
i got superleggera 18x7 40 offset...will it rub if i got 225/35 or 215/30?
with a 7 inch wide rim, and a 40mm offset you should have no rubbing
1 - 10 of 10 Posts
