1 - 13 of 13 Posts
are you talking about the door bumber thing? just heat it up with a heat gun, and try reattaching it. Becareful with paint though and do it quick before the dirt gets in there and messes the adhesive up
Discussion Starter · #9 ·
yes the door bumper thing under /side of the car that holds front splash guard. thanks im gonna borrow my buddies heat gun aand try that. If it's a computer i can fix without a issue cars are a little bit harder and it isn't my Zone.
yeah, I was thinking about the door strips... I don't know about the side skirt... p10 don't have that... sorry so the heat gun thing wont work with that... I don't believe, give it a try, if you see a black adhesive it might work. other than that Id say put some self tapping metal screws with a washer from underneath to hold it in place if possible.
Discussion Starter · #13 ·
thanks fixed it took out all the plugs and clean the inside of it and stripped the adhesive glue/sticker sticky stuff and my friend had this glue goey tape stuff that has worked so far. what was the funniest thing you've seenut a pad in the way and kicked it and it didn't come off so I gues it worked).
1 - 13 of 13 Posts
