I am trying to run the power cable for my amp, I have a 96 G20. I have read some older postes about this topic, some people said theres a gromit by the pedals, I cant find this to save my life i took some dash apart to get a better look but no. Someone also said run it through the wheel well, I took it apart and found the harness and it seems to be a good choice but I cant find a way to run the wire up through all the dash work to get to it. Are these my only options or is there something else?
there should be a hole by where you rest your left leg while driving. this goings thru the wheel well to the engine bay (comes out next to battery). you shouldnt need to remove anything to see it but removing the wheel well lining will make it a lot easier to pass the wire thru.
thanks for the input guys. Yeah Iv seen those holes throught the fire wall and it just looked really tight, so I ended up drilling a hole throught the sheet metal behind the wheel well.
