Aug 24, 2015 - Mar 16, 2016
So, here is the car as it sits....
Basically the same as the previous photo I posted, but dirtier.
Although a lot later than I originally thinking, here's an update.
I have been slowly amassing many parts for this car, a lot of parts. I need a couple things here and there, but for the most part I have the major parts.
So what you see in the pic...
- Fortune Auto Coil overs
- BBS 17x8 LM wheels
- 05 Spec V Trans
- P12 Bell housing (not shown)
- P12 axles
- P12 shifter & cables
- JWT 6speed flywheel
- OEM 350Z/G35 250mm clutch
- Gspec hydro conversion line
- Koyo Radiator
- New VET long block
- MazWorx head studs
- 20V valve cover
- VET intake & 1N5 plenum/throttle
- S13 DET ECU
- S13 wiring harness
- P12 ignition coils
- Wiring Specialties S13 harness rebuild kit
- R35 570cc injectors
- Z32 MAF
- Port-Matched GTiR manifold modified for external wastegate
- TiAL MVS external gate
- GT28RS, disco potato
- exhaust outlet & downpipe modified to clear A/C
- new JDM lower radiator support (not shown)
- New EVO 9 recirc valve (not shown)
- EVO 9 OEM intercooler (not shown)
I left some things out of the photo, either because I forgot about them or I didnt have it there. I'm sure I need to some other stuff, atm can't remember though. The plan is also to get eGT parts on this car too, I just don't have them yet
Hopefully soon.
Probably won't be all at once, for instance, the S13 wiring harness. I'll probably to get it going will use a JWT ecu.
Test fitting exhaust set up on the 20V I have
April is just around the corner, it's this car's 22nd birthday. Happy Birthday!
