S15 GT28R/S15 Injectors/S13 Valve Cover/SS Turbo Lines
208 Views 10 Replies 8 Participants Last post by  hobbs
16
Posting some bits up for sale, going in a different direction with my build and no longer need these items.
S15 Spec R GT28R Turbocharger - SOLD
Only has about 1,000 miles on it, purchased new, no damage to either the compressor or turbine blades and does not have any shaft play. The center section still has not even changed color yet from the heat, this thing is mint!
S15 480cc 'Bricktop' Injectors - 180.00
Came off a low milage motorset when a friend was going to 740cc injectors and a larger turbo charger. Clips and pintle caps are in great shape, no broken plastics whatsoever.
EARLS S13 SR20DET Stainless Turbo Lines - 115.00
Used but in great shape, genuine EARLS lines, comes with fittings for both journal bearing turbos and ball bearing turbos.
S13 SR20DET Valve Cover - 75.00
Powder coated in a satin metallic red that is in great shape, there are two spots on the outer lip that has some minor damage from shipping but as the valve cover gasket protrudes past said lip there should be no issue with leaking.
1 - 11 of 11 Posts
Bumping this up for the S15 GT28R, I just got it installed and spool on this thing is awesome very similar to a T25, I like it more then the Disco I had before.
Oh hell, just got paid, so tempting.
Do it, you won't find a cleaner one other than getting it from nissan!
Thanks, these are awesome turbos.
+2 for awesome turbo and some clean ass parts here.
Hobbs you stay with the hot shit. Thanks for the ams exhuast and calum rt. Good luck with the sale.
Turbo sold! Thanks!
I thought the S15 had 444cc ?? Do you have a part # I can look up?
16600-91F00, seems that there is quite the debate between them being 444cc and 480cc injectors, needless to say that extra 36cc of fuel will not put you into the safe zone and you would need larger injectors anyways. These would be more than fine at 320whp at 3bar.
1 - 11 of 11 Posts
