[2001 G20t auto]
Hi guys, my car is sick again, and I have no idea where to look
The other day i turned it on and there is a loud scraping sound coming from the engine... putting my ear up close, i think its coming from the pulley and belt areas
First Problem:
i noticed the belt along the AC/Alternator pulley appears to have a tear/slit lengthwise -- i recently changed the alternator and I'm wondering if i tightened the tensioner too much? Just a crappy belt maybe? (initially after putting in the alternator, i had actually not tightened it enough causing a whole lot of vibration which is why i made sure it was tight after that)
Anyways i did check the alternator and belts many times to make sure everything was working after the alternator replacement and both were running just fine
Second Problem:
I checked the oil and it was really low, which is weird because i changed the oil last month - i know my car consumes oil, but never this fast - anyways i topped it up with Castrol 5W30 here in Canada where its freezing cold (I feel like the car hates the cold) - am i using the wrong oil?
Turned it back on and the engine didn't feel as rough while driving but the scraping sound is definitely still there
The most recent repair i did to the car was the alternator which was over 2 months ago and it was running fine..
**** There was one and only thing i remember fiddling with before the sound came up the day after: I turned down the temperature down to the lowest position - for some reason i feel like this kicked in the AC and maybe the AC pulley is making weird noises (haven't used AC for a long long time, and quite honestly have no idea when it actually kicks in) - might this be what ripped the belt?
It doesn't respond to turning the temp up and down or turning heater on and off and all the pulleys are turning quite fine - its not just the sound, its actually grinding and lagging when driving it - i just added the oil so i'm assuming that will help but i have no idea what could have caused it to burn/consume that fast
If anyone could help, I'd really appreciate it
Thanks in advance!
