What K&N intake? The drop-in filter, the JWT or Stillen POP with the conical filter, what? If you have a POP, using the two in combination is supposed to be the hot power ticket. If you just have the tray filter, definitely get the CAI.
I guess I'm saying, "Yes, get the CAI."
If it's not a velocity stack like the JWT POP and Stillen intake kits are, you should probably upgrade for the sake of your MAF and ECU readings. Again, I say go for it.
Hell yeah get the HS CAI! Yes it is worth it. I suggest that you also get the Wolf POP Charger and combine the two. Check the FAQ on ser.net for more info on the combination. :smoke:
