1 - 15 of 15 Posts
Silvia (Bigger Pics!)
Made some changes to my ride as of recently...
-New Custom Grill
-Molded Lip Ends and Painted Black
-Custom Lit Corners
-Custom Eyebrows
I think it looks 100x better...let me know what you think
ah yes, much cleaner :thumbsup:
njprimera said:
i made the lip myself from the upper front valence of my old car (92 Camry).
i did all the molding, and custom fit it myself.
how long did that take you to do? Because we have an old camry here sitting in our driveway..
Discussion Starter #10
^^^ the lip took me about 4 hrs total to completley finish.
-you have to remove some bulk from the ends so you can twist the
ends flat so it fades into the bumber nicely. then...since the ends are too
short to begin with, I cut a square of plastic out from the rear bumper
(of the camry), and shaped it to match the lip and extend to the end.
-after thats done, i filled in the visible space between the extension and
the lip with bondo so that it flowed well. once that was done and i painted it,
and everything looked perfect.
it takes a good bit of work but i think its def worth it
Looks great man! I can't tell cause the resolution on my monitor sucks, but do you have black mesh inside the grille or is it just open? awesome work!
Discussion Starter #15
whats up guys
yeah that is a stock grill modified via Ericdd's How-To
and yes there is mesh behind the grill
maybe you can see it better there
dont know why the grill looks weird in the top center there...
it looks fine in "real life"...so to speak
1 - 15 of 15 Posts
