I have a new 02 G20.
Does anyone with a new G20 have a problem with there clutch being weak, or slipping when shifting into second?
Only slips when engine is pushed hard, meaning going to redline then shifting clutch tends to slip. It doesn't do it under normal driving conditions.
G-S,
Yea, the P11s come with a 'grocery getter' pressure plate. You trade a little slip for smooth engagement. Also some late models have problems with uneven clamping force on the plate. That causes the clutch to chatter as you release.
If your clutch is adjusted correctly, the slight slippage is normal. Try to get off the clutch quicker than with other manuals you've owned.
The only alternative I can recommend is a JWT pressure plate with stock disc.
Manz
