1 - 2 of 2 Posts
Hello
I am having an issue passing smog in NV Las Vegas . When the ign is on the CEL light does not turn on for that quick sec . I scanned the car no CEL light . Checked the bulb in the cluster it is good . Battery is fully charged and alternator is good. Already tried to reset just the ECU . And tips on why the light does not turn on for that quick sec. I can not pass smog here for that reason .
Car is a P10 1996 , 221,000miles
you check for bad connection while you where checking the bulb you can check for constant current, it sounds like a short if you are getting it to light up for a second.
1 - 2 of 2 Posts
