Only for the rear. Like tony said the front is totally different. Did you get a spring compressor?and can the instructions from b15sentra.net apply on the p11 also?
Just from the front. You'll see a little clip that needs to be removed so you can clear the line from the suspension. You need to do this otherwise you can't get the clearance to remove the shock, not to mention it's tough to get a socket or wrench on the bolt/nut if you don't remove it.akuma810 said:yup got the spring compressor. do the brake lines need to be deattached?
Uh....I didnt get it....akuma810 said:Yahnozha... one word.. you own..
