link
jun what is there website if anyone knows?
by the way does luke deal jun parts i know its expensive as hell just wondering if he does if so do they make parts interchangeable from the s14 det they did that will go onto the SSS det or gtir
casual
just wanted to share an interesting link
That pic of the BTCC engine shows the head installed in the conventional manner. I had always understood that they turned the head around on those engines...curious!?! :-\
as far as the heads i beleive someone posted them before on af but i dont have those pics and yes it did look diff...
i'm curious about this too cuz i dont know too much but am learning daily while researching
casual
courtesy nissan in texas sells jun parts for fwd det
link
28/8/01 - SPEEDWORKS JUN S13 (700+ HP)
With 600hp out of a wet block 4 cylinder most people would be suitably impressed. However Speedworks quest to have the highest horse powered 4 cylinder in Australia saw the crew spending more time trying to extract even more horses out of the SR20DET.
On the morning of the 25th August 2001, their efforts were rewarded. An unbelievable 732hp at the wheels was recorded at Perth's GENIE Performance Exhaust Dyno, in the presence of a small crowd that included:
Stephen Wilkinson From ELF Racing
Members of the Silvia Car Club of WA
Driftworks.org
(Dyno Chart available for viewing)
Details of Run:
Fuel: ELF TurboMax 101.8 RON Unleaded
Boost: 1.9 Bar
Dyno: DynoJet dyno, Set up and Run by Staff of Genie Performance Exhaust centre
What's next for the JUN SR20DET?
Possibilities are endless, being a wet block the engine may find itself in use for street, track or even drag racing, (imagine a 4 cylinder dragster that can drive itself back to the pits?) Rumors are flying fast as to the final destination of the engine. Speedworks has remained tight lipped about what is happening but have said that they will be announcing their intentions soon.
The SR20DET was using full JUN components & ELF Racing Fuels and oils.
you have to sell some of your kids and maybe a kidney to afford jun
but it works
here are some prices
JUN 2.2L Stroker Assembly (87mm x 90mm Stroke):
JUN Stroker Crankshaft and Pistons
SR20DET, Must use RNN14 Flywheel, $4579.00 Kit
JUN Custom Stroker Kit:
Same as 2.2l Stroker Assembly plus JUN Connecting Rods
SR20DET, $7006.25 Kit
JUN SR20DET Piston Kit:
87mm Bore, 462g, 12.1cc Dish, 22mm Wrist Pin, 1335.70 set
JUN Connecting Rod Kit:
SR20DET, 1028.85 set
JUN Camshafts (SR20DE/T):
Solid Lash Type
264 Degree 10.8mm Lift
272 Degree 11.0mm Lift
280 Degree 11.5mm
Hydraulic Lash Type
256 Degree 10.5mm Lift
264 Degree 10.5mm Lift
256 Degree 11.5mm Lift
264 Degree 11.5mm Lift
272 Degree 11.5mm Lift
All available as either intake or exhaust
Priced at $335.35 each
JUN Valve Springs (SR20DE/T):
Single, $199.50 set
Double, $304.00 Set
JUN Valve Retainers:
SR20DET (PS13), $409.45 set
SR20DET (RNN14), $409.45 set
JUN Valve Guides:
SR20DET, $194.75 set
JUN Adjustable Cam Gears:
SR20DET PS13, Intake or Exhaust, $171 each
JUN Flywheels:
200SX, NX2000, G20, Sentra SR20DE
Lightweight, 10.56 pounds, $403.75
Ultra Lightweight, 9.68 pounds, $451.25
JUN Billet Aluminum Oil Filler Cap:
SR20, $80.75
Specify Silver, Gold, Purple, Blue, or Red
JUN Intake Manifold:
SR20DET (R/PS 13), $2470.00
SR20DET (S14), $2956.40
Discussion Starter #8
yep something is telling me i may some time in my life run into a pile of money but anyway i figured minus well learn all i can now so when i do get it i dont have to come here and post a repetitive post saying "umm how can i make my car faster" and so on
anyway i don't know if i should keep posting the info i find i'm glad you find it interesting for that reason i will keep sharing what i find and learn
casual
