So I spent the past couple days replacing my timing chain, water pump, guides, front main seal, fresh RTV, and I have to say, the engine on my G20 is much less noisy and isn't a leaking mess anymore.
However, I still have some noise coming from the head. It is not rod knock, trust me, it is NOT rod knock.
I haven't pushed on the lifters yet, but I suspect they are causing the annoying tapping noise I've been hearing for the past couple thousand miles. When I had my motor torn down for the timing chain install, everything was visually in the head appeared to be in good shape.
To my question now, has anyone gotten away with pulling their lifters and just bleeding them to remove the noise? How long has this held up until the lifters started making noise again? Does it matter if you bleed them with lighter/heavier weight oil?
The other more expensive option would be to replace the lifters, which I'm not opposed to, but don't want to take this route if I do not need to.
So I'm asking for some help and advice, I want to have my car running rock solid before the winter. Any hydraulic lifter experts please chime in.
