Hey guys ,
Can anyone tell how the automatic transmission TV cable type, should be wired to the sr20ve ECU ?
Well just the overdrive and the torque lock up.
Which wires are which on the transmission and how they should be connected to the ECU.
thanks
will add picture tomorrow.
The connector has
1 pink wire -
1 orange wire (middle wire)
1 yellow wire -
i just need to find out which wire is what. From read on line one should be a ground wire, overdrive (which is normally open) and one should be 12+ V to switch on the lock up.
