1 - 20 of 24 Posts
Below are some pictures of a modification I did to the SR20VET Turbine housing to allow for the use of the Avenir or Bluebird Jpipe elbow since the stock SR20VET Jpipe will not work, enjoy.
Stock SR20VET Turbine vs Modified SR20VET Turbine Housing
SR20VET Turbine Wheel Inducer and Exducer measurements
Just a bunch of various pics of the process
That's a great idea! A whole lot better than cutting a custom flange.
Discussion Starter #5 (Edited)
FYI cause i've heard statements made that the SR20VET was ball bearing and i'm here to tell you the at least the 14411-8H600 is not ball bearing and that's the part number tag on the above SR20VET turbo it has the 4 bolt pattern on the inlet side of the turbine housing where the CHRA connects whereas the ball bearing units have a 6 bolt pattern just like the S14 S15 and the W11 ball bearing turbo's do.
We have rebuilt several VET turbos and all of them are journal bearing. Another cool thing is they use the exact same compressor wheel part number as the GTIR turbo.
Discussion Starter #14
P11 SR20VET Compressor Outlet Pipe (2.5") designed to clear OEM P11 fans, does require removal of front engine mount and slight recess of an area of the crossmember (very tiny talking about 1/8") well only be making one more besides this one, this one is for sale pm me if interested
The piping (3") with the BOV/CBV bung and valve cover bung is also for sale pm me as well if interested
*Turbo is not for sale just for picture purposes
Discussion Starter #16
good shit Charlie, you might be able to make a front mount with some bushings to be sold with this.
y2kg20 made those "L" brackets and that's what I used for my vet
Thanks man, I made an "L" bracket but still not decided if I wanna make it able to be solidly mounted and or optional solid and or bushing mounted
mine was solid mounted.
but when we put my motor into Jorge's p11,
we cut a sway bar endlink bushing between the "L" bracket and the subframe and it helped with vibrations alot
1 - 20 of 24 Posts
