I have a 93 g20. how do you take out bolts that you cant see??
I took out the one with the threads showing. The other one i cant get to. Actually i cant find it.
Have you removed everything you need to get to the bolts? When I took mine off, I had a little trouble at first, but you just have to move some of the hoses out of the way and use an extension to reach the bolt. It is a good idea to have someone under the car to hold the starter while you unbolt it so it doesn't drop and damage anything. I've only done this once, so if anyone else knows different, please chime in.
