A couple days ago, my car won't crank, I can hear some type of electronic motor running without cranking; however, after a couple of tries, it started up and working fine now.
I took it to a local mechanic and explained what happened; he thinks it is the starter.
The thing is the starter was replaced about 2 years ago, and about a year ago around this time of the year, the car did the exact same thing and worked fine until now, and it did it again but working again now.
Do you guys also think it is the starter?
Does it die suddenly like this? or Can you tell a starter is due soon?
If I need a starter soon, which starter should I get? I've search this forum and people say a starter from Autozone and Napa is bad.
BTW, I have a 2000 G20 Automatic.
