1 - 8 of 8 Posts
Well Guess Im stupid. I was messing around with the wiring of the remote starter to get it to work and I had the 2nd stater wire hooked up to the relay. I guess the relay caught one of the metal pieces and made a spark. Now the car wont start. The dome light, security light head lights, and horn work. The dash lights do not work. I checked all the main fuses under the dash and they seem to be good. Maybe a relay some place or another fuse might have blown. Anyone have any idea on what can be wrong?
Pizdeet kak Trotsky
Surely if the batt fuse had failed ....... Nothing would work ......... Still I dunno
I tried to check the battrey fuse but I cant pull it out. Same with all the fuses in the drive frender. One fuse I think its the ignition one on the same side I was able to break off the plastic and test it. It seemed to be ok. But I cant get to the other ones. How do you take these damn things out?
check all the ones in cabin again, test them with a tester for continuity, not just visually, then there should be a starter fuse, that's the one I think would be your problem. Also theres one more fuse box near the airbox check that one out, I don't remember what fuses are there. Good luck bud!
It turned out to be the fuse near the air box. The funny thing was that I looked at it like 5 times and it looked alright. I gave it a few days then tried to attack the problem again and I realized it was the ignition fuse near the air box under the hood. I went to Pepboys and got the fuse for $3.99 and replaced it (way cheaper then paying the delear for the fuse i think they charge 15.99 or something). The car started up. :).
Thanks for your help guys.
1 - 8 of 8 Posts
