Hey guys, so I have a 2001 G20t
A few months ago the battery died, so I replaced it and everything was good
I had a problem where the car wouldn't start, just the clicking sound when I turned the key
I immediately assumed I didn't tighten battery connector properly, because after I wiggled it, the car started fine.. Eventually the problem kept returning and wiggling the car while seated actually got it to start while turning the key as well.. I've disconnected, cleaned and reconnected the connectors but the problem is still here
I've read the other threads about a possible bad starter, but it seems the car starts fine if I just rock it back n forth
Can anyone help with what I should do to check for very simple problems?
I feel like its a bad connection because it happened right after replacing the battery
Also, is it possible a fuse is blown somewhere?
Thanks in advance!
Thanks in advance!
