1 - 8 of 8 Posts
This is a 'possible project' for anyone willing to undertake it.
Last year i was able to pick up a Stillen 4-1 primary, brand new, for dirt cheap. Obviously it needed a secondary to become a full header. Through research i came to find that the JGY 2.5" turbo downpipe was the ideal candidate. I had spoken with the owner of Custom Car Performance(http://www.customcarperformance.com/indexmain.htm), which are literally down the road from me, and he informed me that he knew of the stillen and knew it under-performed. He said that he believed that a larger b-pipe would help with providing more power, as in the SSAC.
Needed to make it all work:
The JGY's height where it meets the stillen would need to be shortened by 2.5", and that same flange would need to be turned CLOCKWISE about 10-12 degrees. Thats it. Everything else lines up, including all bolt holes, which at the stillen/jgy flanges are both 3.25" apart.
This is just an FYI, and i would only suggest doing this if u can find the parts dirt cheap. Just thought this would be valueable info for anyone who might have a 4-1 stillen primary and no downpipe.
Mike
I have a stillen header with a nice sized dent in it. I may try this in the future. I figured it would be a nicer header with a bigger pipe, but I never had the HP for it to matter.
Please let me know if you do ever undertake it. I'd be very interested to find out how it works out.
I probably won't for a while. this would be something I did if I got a ve or do a high compression motor. so unless my fles pip gives out sooner then I think, it will be a while. you got both parts, how come you didn't try it?
I was maybe about 2 weeks from having it all fabbed up when i bought the Impul header. This would have been interesting but the Impul more so.
looking at the secondary in that other post, the JGY pipe is reduction bend and pretty nasty too. do they make a mandrel pipe as well?
Discussion Starter · #8 ·
i dont believe so, but if someone else does as long as its 2.5" and bolts up to a stock det t25 then you should be good to go.
1 - 8 of 8 Posts
