1 - 1 of 1 Posts
Problem: I have a 95 g20 that has the factory sunroof. When the sunroof is in the close position, it seems to be about 3/16s lower on the back edge than on the front edge when compared to the roof top surface. If I open the roof by using the 'up' button and then close, the sunroof is above the roof line on the back edge. After hitting a few good bumps or pushing the sunroof forward, I can get it to drop down to the first position that I noted.
Question: Is there a solution to this problem like an adjustment? Or is it a problem that I have to replace the sunroof hardware? Can I add shims to the slide tracks?
TIA
John
1 - 1 of 1 Posts
