p10 vs. b14 suspension...
my buddy has a b14 and he was wondering if the suspension is the same. He ordered a set of ksports and he thinks they are too stiff cuz his car is crazy light. So I talked to ksport, didnt exactly get a clear answer so I wanted to know from the direct source. I had a customer order ksports from me on his p10 and he got a set of 5kg (280lbs.) spring rate for his rear. Are the springs the same on the p10 vs. b14? height? diameter? etc.
thanx in advance...
no a p10 has full indepent suspension..a b14 has a rear beam..i believe.
Front: P10 multi link (one fixing point at bottom)...B14 MacPherson strut (two fixing points at bottom)
Rear: P10 Chapman strut (two fixing points at bottom, three studs at top)...B14 Beam (one fixing point at bottom, two studs at top)
That's ignoring and differences in length etc...
Now the springs on Ksports are all the same diameter, the lengths vary depending on the spring rate. You'll find a chart for D2 spring lengths/spring rates/wire thickness on http://www.d2racingsports.com.au/tech.html
