1 - 2 of 2 Posts
Hi guys.
My car has been stalling out for some time. I've already tried a number or solutions including cleaning the throttlebody, changing PCV, plugs, wires, fuel filter, cap and rotor. Oil, etc. Basically a general tuneup. I want to test my idle but the problem is....I can't see RPM's, tachometer has been dead for 3 years.
Dealership says I need to replace entire instrument panel $500 + labor.
Engine is throwing a code for not detecting the RPMs (forgot what code right now). Is it possible that it's just a sensor gone bad? If so...which one?
Thanks.
Jerry
buy a digital timing light, the stock tach is far from accurate when checking timing and setting base idle...as for your tach not working, go download an FSM from phatg20.net and do some troubleshooting.
1 - 2 of 2 Posts
