Status
Not open for further replies.
Pining for "DMSentra"
Notice there is no mention of the size of wrench to use on the bolt. When you ask for a 10mm bolt you will normally get a bolt that has a 14mm hex head on it. When you ask for a 19mm bolt the fella behind the counter will know instantly that you failed mechanics101.
There are two ball bearings between the knuckle that houses the wheel bearing, hub, and outer axle end, and the 3rd link(upright) above it. One 6203-2rs bearing and one 62/28-2rs bearing per side. These number are for sealed bearings that come pre-greased. There is also a seal at the bottom of the 3rd link that you may or may not care to replace with it. If you use non-sealed bearings you will need to replace those seals and grease the bearings before assembly.
The parts I'm referring to are #9(3rd link/upright) and #8(knuckle) in this drawing.
Video on drilling and tapping threads in a hole.
Remember a couple things while doing this. Taps are fairly brittle and break somewhat easily. Don't bend them, and use caution that you aren't overpowering the strength of the tap as removing a tap broken in the hole brings a whole new level of frustration to the project.
http://www.youtube.com/watch?v=KVnN4jiB7Gk&feature=related
Discussion Starter · #5 · (Edited)
These are fairly good calculators for determining what size injectors you should be running to achieve a certain hp level, and, what increasing fuel pressure (psi) will gain you in increased injector flow.
http://www.witchhunter.com/injectorcalc1.php4
Maybe I'm missing something but I'd like to see what fuel pressure these figures are arrived at.
Status
