1 - 20 of 24 Posts
Ok I'm signing up for the group buy and I have some requests/questions.
first can i get some pics of the top of the front and rear mounts with Tein ss installed, and pics of the coilover assemblies before install. I have searched not coming up with anything. I want to put spacers at the top of mine to reduce the lowering range of my setup, so instead of 2.1-2.93 lowering front and 1.18 to 2.83 rear I want to make it 1 to 2 and .5 to 2, this way i can keep it in the 1.5 drop range and stay in the coilovers sweet spot and raise it a half inch for winter if necessary. I'm thinking of using a combo of properly fitted washers on the upper shock rod below the shock mount and custom spacers and longer bolts on the upper mounts themselves. so a decent pic of the stock mounts unmounted would be nic to. thanks! any comments advice is welcome.
and yes my wife is gonna kill me.
David
i can take pics of the tops of all the mounts, after work.
the wife might kill you, but your P11 will LOVE you for it.
Hey! You want to PM your fon #? I can give you a call to better explain about the these. I have then and I'm with you, I didn't want the super drop they say and I was able to accommodate that. I can explain it better talking than typing! lol
KEKEKKEKEKEKE mommy didn't approve, until she rode in it.
comfort - 1 (compared to H&R sport springs on stock shocks)
bounce - 3
*mine are set to the softest damper settings*
edit: scoring corrected
Discussion Starter · #8 ·
comfort - 10 (compared to H&R sport springs on stock shocks)
bounce - 3
I'm hoping you got your numbers mixed up. you mean these things are going to give me kidney failure? so does that mean the 3 is good or bad?
Discussion Starter · #14 ·
Big Mahalos for the pics. Man looks like alot of unused shock rod thread sticking up. I'll get atleast 1/2 an inch to 3/4 just in shaft spacers. I have a fairly simple design in mind if i need to build a custom mount, but after seeing those pics i think i'll just use spacers on the shaft and some more spacers between the front mount and shock tower. if i can get the old front mount bolts out
Discussion Starter · #18 ·
umm I'm not trying to go lower, im trying to go higher.well higher than where Tein SSs will put me. like I said I want to keep my coilover adjustments neutral so I stay in the middle of the coilovers sweet spot. and I only want to drop and inch to a inch and a half front and 3/4 to an inch rear
Discussion Starter · #20 ·
I wonder if they have intermediate spring seats and helper springs that i could purchase to add to these. since im not going to be lowering much i could use the extra adjustment range to add these. and I wonder what rates the helper springs come in. if i could get a short 180-200 helper wouldnt it be almost like having a progressive rate spring?
1 - 20 of 24 Posts
