Hey guys, my engine on my 94 keeps ticking from the top of the block. It increases as the revs go up to a certain point. Is that something witht eh valves and lifter? How hard/expensive is it to fix all that? I just bought the car. Here is what I am going to do
Change AT fluid, oil, coolant
Change drivebelts, PCV valve, o2 sensor, distributor rotor and cap, spark plugs, plug wires.
What else do i have to watch for, the engine has 126K on it
Not to freak you out or anything. but I got a sound from the top of my engine after I raced it a bit (I had just bought my car with 130K miles on it). I didn't know it then but I had spun out my connecting rod bearings or some shit, and later, my engine completely went out and I had to get an engine swap. I doubt it's something as extreme as that...but who knows. Just get your entire car checked out, especially if you've just bought it.
I think I had dented my oil pan, causing engine failure (SR20DEs are horribly sensitive about that). I learned my lesson. Don't drift over loose sand. Going over curbs at high speeds breaks things, and also helps reduce the risk of going into ditches....
ok I had the same problem but my car is a 1999 and only 62K miles. You say it makes a clicking to a certain point...I am guessing around 3K...well I asked this question before and it isn't the rod bearing...because you can hear that in any RPM...Its your lifters...one must have went bad or something...what you can try is using thicker oil....by doing this you close the gap...if the sound goes away then you know its lifters...
I talked to my friend, he said it is lifter too. See I dont think it is a connecting bearing because it doesnt sound like i spun a bearing. This is what it sounds like at idle
tick,tick,tick,tick. As rev increase, it tends to die down, then at certain RPM (around 3000RPM). It comes roaring back. I am not real familiar with how a piston engine works, but i am thinking either the valves or the lifter. I found the valve is out since it is hydralic. So how much is it to fix the lifter? How hard? I dont think i will touch it myself since i dont know much about these engine. can you guys tell me how much it is to fix it. thanks
Honestly I think it would be pretty much how much it would cost to change cams...I have a 1999 SR20DE in my garage and I recently pulled the cams out...and then the lifters and shims...so pretty much cam labor plus parts..I'm guessing on this...
What would cause a ticking sound that is heard only when accelerating under load, (in gear) but not when revving in neutral or at idle, and not at start-up? The noise is only heard when accelerating with the wheels are on the ground. Front-end elevated, with transmission engaged, there is ZERO ticking.
Only is heard when in gear, wheels on ground, from 2K to 3.25K rpm or so.
There is a hole in one of the EGR plugs, under one of the runners on the upper intake (p10). Soot builds up on the coolant by-pass hose, there. There is also a "tear" in the exhaust flex pipe where it meets the exhaust downpipe, but there is no deep, "hole-in-the-exhaust" sound.
