1 - 7 of 7 Posts
i replaced 3 OEM clamps around the power steering reservoir this weekend with worm drive clamps. my question is how tight can i go on these clamps? i am concerned to actually make them tight and break/crack my reservoir lines?
my drippy g needs you
YOu wont break the tubing the gears will strip before that. But anyways, just use common sense as to tightness. Obviously if the hose ends up looking hour glass shaped, your too tight
i always go as tight as i can with whatever driver im using. iv also replaced just about every single nissan hose clamp with worm drive clamps, they should hang the guy that invented the oem ones
1 - 7 of 7 Posts
