I am having trouble removing the timing chain cover/front cover.
trying to set the cam timing so I can line up the chain but the cover won't pop off.
What am I missing here? Sprocket is off, the bolts are off, the top will pry out but the bottom is stuck and it is stuck around the crank. If pry any harder, I'm sure it will crack.
The Mitchell manual and the Chilton's both say "remove front cover" and shows the bolt location. Thats it.
I didn't see any threads so????
The gasget maker isn't that strong.
any ideas out there?
frog1975,
93 g20
drive it like you stole it
frog1975,
93 g20
