1 - 2 of 2 Posts
I know this will sound stupid but I am ready to advance my timing to probably 19* but I can't seem to see the little markings down by the belts. If someone could help me find it or has a picture it would be really helpful. And here is another stupid question but being tired is screwing with my brain. How does the timing light work to get the timing? Sorry for the questions but drawing a blank at the moment.
It's just basically an inductive pick-up and a light. The inductive pick-up will read the spark off one of your cylinders and can determine the rpm. If you can't change the timing on the actual gun then it will flash the light at 0 degrees. If you can change the timing all it does is advance or delay the flash until the proper time of the advance or retard you have set. Pretty basic actually.
1 - 2 of 2 Posts
