tire size
4528 Views 17 Replies 11 Participants Last post by  CovertRussian
what tire size are you running in you P11 or P10?
me p10
before:
195/60/14
205/55/15
205/50/16
215/45/17
225/40/18
about to put on
225/50/16
what is the biggest tires you had use before and what you are using now?
1 - 18 of 18 Posts
205 50 15 on p10
The largest/widest tire that fits without too much work is a 235/40r17 on a 17x8.5" wheel +35 or so. I ran those for years.
New setup is 245/35r18 and 225/40r18. Car is tubbed and slammed/lowered etc so I had to make room for them. Excessive for about anyone else but my reasons for doing so are always crazy (like me)
225 45 15 fit after fender rolling and pulling with ET35 on 15x8 wheels in front (et40 15x7 in back though)
I run 225/45-16 on 16x8 +35 at the track and 205/40-17 on 17x7.5 +47 for daily driving. Fenders rolled until lips flat
Not tryin to thread jack but you think 225/45 on 15x8 +18 would fit
Anything 8" wide beyond +35/+30 or so you have to MAKE fit. Meaning clearance and all. The wheels may bolt in and fit but will require new UCAs fender rolling/cutting and or other mods. 8" wide with a +35 fits pretty good with only needing to roll the fender lips
205-40-17 8'wide wheel rear fenders not rolled isn't rubbing. But tire is stretched a bit.
what i am about to put on is 225/50/16 +45 6"
what do you all think of 235/40/18 7.5w +42 on am p10?
Good luck.
You do realize that tire is 1.5" taller than stock right? I clearances as modded a lot of stuff on my car for 225/40r18's to fit and its still not perfect. Mostly only has issues at full compression, and my car is extremely low, but unless you are at stock ride height it will rub like crazy turning.
Oh. And those tires may not even fit on those wheels. 8" width minimum unless clean china tires. And at that offset they will not clear the 3rd. You will need a 10mm spacer
I originally had planned on using 205/40-18 on 18x7.5 +40 but I never got around to installing them.
Eventually I went with 205/45-17 on 17x7 +40 and they fit nicely.
This is on a P10 right? Which means on P11 should be a little more forgiving right? I've been going by the sticky list, which basically says +42-45 offset, which has greatly reduced the wheel options. If I can run 225-235/40-45/17x8" +30/+35 with just fender lip rolling that would be awesome.
1 - 18 of 18 Posts
