1 - 2 of 2 Posts
I have two of those cotton type sheets inside my sealed box which are suppose to trick the sub into thinking that the box is bigger (this is what I was told). I still have a lot of room to put more of that white stuff inside. Should I put more in?
I wouldn't. As long as you built your box to the manufacturer's specs, you're not really going to be able to improve much on it. Just use a single layer to line the inside of the box. That's my best advice; I'm not a pro at this, but I do know what sounds good. You can always try it to see if you like it, but don't be supprised if it makes your sub quieter. To some extent it's a matter of preference depending on the music you listen to and what you want your sub to sound like.
1 - 2 of 2 Posts
