1 - 2 of 2 Posts
V3.0 VE-T
Hey guys, i was wondering if this will work. A Tomei 256 Poncam cam with a stock exhaust cam on a 96 g20. Will this work out fine? My other question is with the S3 cam. Do i have to use both Tomei and S3 cams as a set? Or can i just run the intake cam on either one?
Mautai916's question is a good one.
<<Hey guys, i was wondering if this will work. A Tomei 256 Poncam cam with a stock exhaust cam on a 96 g20. Will this work out fine? My other question is with the S3 cam. Do i have to use both Tomei and S3 cams as a set? Or can i just run the intake cam on either one?>>
Which cams are most equivalent to a 1991 stock cams? I have pitting on both intake and exhaust cams. I have cleaned out the oiler tubes, but need to replace the cams.
1 - 2 of 2 Posts
