1 - 8 of 8 Posts
considering this forum has helped me more than any sentra forum could in regards to a b15 tranny swap [insert lol here] i figured i'd ask this as well.
to those that have done auto to manual swaps can you guys tell me what you can remember as far as tools needed? I just wanna make sure I have as much covered as I can before I actually attempt this. I dont wanna get stuck midway because I dont have the proper tools.
ok you need a full ratchet set- 17mm,12mm,10mm,14mm as i remember
you need a breaker bar
jack stands 2 hydraulic jacks (one to support and remove tranny)
you need some 12 point sockets for the flywheel bolts 14 or 17 i think i really cannot remember note the 12 point
and all the manual parts and a lot of paitence, do extensive extensive research its not an easy task.
what i gave you was an idea no details there it s been so long, so reseach
trini
I dont know if the B15 has the 36mm axle nut, but youll need a socket to get that off.
Other than that, an air grinder/dremel, impact wrench, and most of your basic tools will help. A torque wrench if you have one. Those threads will help you as a basic guide, but to each his own.
1 - 8 of 8 Posts
