I have my POS 96 nonLSD tranny that is getting dumped. Anyways, I'm thinking of going LSD and wanted to make sure that the only other thing I need, besides the transmission, are the axles (aka drive shafts) from a T model....is this correct? If so, what's the difference between the LSD axles and non LSD one's, just length?
Thanks,
Jonathan
p10 guru
im going to be doing the same very soon. i already bought a lsd tranny from an se-r. i believe you only have to change the driver side axle. maybe someone can chime in for us
I've looked around and besided maybe replacing the seals I think that's it.
From what I can tell via the napa online store, there is a difference in driver's side shaft but I'm not sure about the passanger side...maybe length.
What year Sentra 2.0 trannys fit in our P10s ?
p10 guru
pretty sure that you and i would need a 93+ tranny because of the electronic speed sensor as opposed to the cable speedometer but im not 100% sure on that either
