i'm planning on doing a pulsar det swap into my p10 sometime within the next year. i've heard that the stock transmission can safely handle up to 250hp, but if thats true, i'd like to get a new transmission that would be capable of handling more hp. where can i go for this?
Your choices are limited..
Get a later RR P11 or B15 trans, or get a spec-V trans and get all the parts that are needed to fit that, like a Japanese P12 (W)20V bellhousing and other parts.
I'm sure you'll find info on both on here if you search.
you could get your transmission shotpeened & cryo-treated. p10det (mike) did that to his i think. the p10 has a better transmission for turbo anyway cuz the gearing is longer, the problem is its weaker but if you get it cryo-treated and shotpeened that'll beef it up a lot.
cool thanks for the help. so from what i've seen when searching, some people say it can support up to 400hp? is this true cause that'd be pretty nice? where can i get the spec-v transmission online? and also what parts do i need to fit it onto an sr20?
