1 - 2 of 2 Posts
I have a '00 g20t.
My check engine light has been on for a while and I took it to a nearby shop. They came back saying the problem code was P0740 - and had to do with the TCC solenoid. They said when the tcu or tcm (cant read their handwriting) detects open or short in torque converter clutch, TCC solenoid or circuit / no lockup.. what exactly does that mean and can I fix that myself or do I have to take it to a transmission place? The mechanic said something about how I can put some fluid in the transmission where it will pass the state tests or actually fix the problem. Also, before I took it to the mechanic, I had my 115,000 mile inspection at the Nissan dealer and they said the overdrive solenoid needs to be replaced... Any ideas guys? thanks
drunken master
i beleave when you buy the sloniods you get 3 and most of the time the valve body need s to come down.
you should inspect wires on out side of trans for the soliniods and check fluide condition cuase soliniods can clog
1 - 2 of 2 Posts
