Ok I have been talking about led's on my 95 g20 in the tails and the front/back turn signals, i have found out where the flasher is in my car, It is right in front of your right knee behind that panel; to the right of the radio.
Ok how do I get to it and how do I take it out, my leds are blinking fast and im buying a new flasher that works with leds..............Can any one tell me what panels to take off and.or what screws to remove to get to it to replace it??????????
Pizdeet kak Trotsky
You don't. You put loading resistors on the bulbs
^ exactly. you should be able to buy em from where ever you got your LEDs.
theres nothing wrong with your car. LEDs use much less voltage to glow, so your
car thinks your missing/have a dead bulb, and blinks faster to let you know.
load resistors are your answer
I know I can use resistors... But if you just replace the flasher unit with one that works with leds there is no need for resistors.
dude your just making more work for yourself than is necessary.
it doesnt get much easier than using resistors.
but i believe the pannel your talkin about is the same one
that needs to be removed to get to the ecu. just pull the thing
towards you and itll pop out. i think its just held in by clips.
