1 - 1 of 1 Posts
It has been a LOOOOOONG time since my last post… there is so much information on this site that all you have to do is read to fix any trouble on your G…
This is for all electric freaks, because I couldn't find any post with the same symptoms…
My turn signals AND hazard lights stopped working a few weeks back, but they have strange symptoms…
When you use the switches, left or right or hazard, you can hear the relay(s) clicking and the lights will NOT turn on; BUT if you use the key FOB to open/close the doors, then they will work…
I started looking under the dash but found nothing suspicious…
Suddenly this morning, thanks to a pothole, they started working again, BOTH the turn signals and the hazard lights, but only for about ten minutes… and because of a bad road, they stopped again… What puzzles me is that the key FOB will have them light up with the button(s)…
Fuses are OK, and I believe the relays are also OK because if you sit inside the car and press the buttons on the remote, you can hear the relays clicking and the lights flashing.
Any suggestions on where to follow next?? I'm thinking beneath the A/C controls, behind the dash...
Thanks,
Robert
1 - 1 of 1 Posts
