Pizdeet kak Trotsky
I left my car out overnight the other day ....... Not a cold night really 9/10ºC
Went to start it & it sounded really ill :x Big Top end rattle ....... Infact so bad I turned it off & checked to see if it had any oil in .......... Oil level fine ....... Car looked ok ...... No one had tampered wiv it ....... Turned it on again .......... Fine ....... No clunks bangs farts or anything ........ It ran fine too ..........
This morning turned it on ..... Started fine nothing outta the ordinary :shifty:
I wonder what that was all about ? :scared:
60K motor
:beard:
p10 guru
i started up my 95 G (summer car) the other day after sitting for the past 2 months and it sounded like it was running on 2 cylinders (ok it was probably 3, but it sounded ill). smoothed out after a few seconds
Maybe a moment of fuel mixture being wrong? How are your oxygen sensors? Mine need to be be replaced and the idle is getting pretty low and rough as the mix gets thicker the longer it sits on without moving.
