So is it OBDI (only has two rows of pins) then if so then just look at an OBDI P10 ECU pinout it will probably be the closet thing you'll find.
So is it OBDI (only has two rows of pins) then if so then just look at an OBDI P10 ECU pinout it will probably be the closet thing you'll find.Does anyone have a pin out diagram for a UKDM 95 P10 ECU? It's not the same as the OBDII USDM ECU from what I can tell. It's got a blue plug, part# 23710 83J01.
