You can use VE springs. You need the VE retainers as well and add an inner spring seat. H22 spring are almost a direct fit. Even a VE stock spring setup is better. Most RR motors don't make power much past 7000 anyways so stock VE springs are probably ok. But any VE drop in spring will work
