21 - 38 of 38 Posts
Great I needed these values, Doing Valve cover gasket tomorrow, good thing this sticky was here.... ;)
CarloSR said:
And why is this a sticky ?
I think he is referring to the come back from J..M's sig again. Still not funny.
There is tons of material here to create a new joke, something about busting a nut and getting your threads all sticky. :LOL:
Ok so i dont know why anyone needs to know specific torque values for 10mm bolts. They're not head bolts, you tighten them until they're tight and thats it. Use a 1/4" drive ratchet w/ a 10mm deep socket and tighten with one hand until you feel resistance and thats good. I use my 1/4" air ratchet and when the ratchet stops the bolt is tight, its quite simple and no you don't have to be paranoid about a Valve cover gasket leaking because they seal good, and if you see a little seepage, just tweak them a little.
Because some people have a habit of snapping small bolts.
I never use a torque wrench apart from critical components like head bolts, bearing caps etc. Otherwise it's tight enough for the size of the bolt :)
If you don't want to use it that is fine it is your car but you can't argue against someone that wants to follow the book. I look up most everything mechanical, cosmetic parts are tight enought they don't fall off the car. I got some torque wrenches, might as well do things consistantly for things that matter.
Yeah thats what i'm saying. You don't have to wrench down on 10mm bolts. They are simply hand tightened. Probably 90% of bolts torque specs are irrelevant. Unless its inside the engine or wheel lugs. Just tighten until its tight. Dont over tighten, its as simple as that
Indeed it does apply to all. The only difference is the DET's have coil on plugs with a 10mm that needs to be removed to pull the coil off. DE's just have a plug wire
According to my sources there is a very precise way of doing this. I don't have a picture but here it goes. U tighten nuts 1-10-11-13-8 to 35 in. Lbs then tighten them in order 1-13 to 87 in. Lbs
21 - 38 of 38 Posts
