Hi guys need some help ! Everytime i make turns left or right and step on my brake,i can hear a weird sound in front .It's like a loose metal the sound was just like TAK TAK Tak.Sorry but this the best way i can describe to you guys how the sound like.Hope you can help me or at least give me some idea waht's wrong with my car.Thanks.
Have you checked your brakes? It could be that the pads need to be replaced. Or if it is a clicking type sound, then the CV joints could be bad. Check under the car to see if the CV boots are cracked/split. Without a little more information, it is hard to pinpoint the exact problem. These are just a couple ideas of what could be making the noise.
similar problem
i have a simalar problem like that it could maybe be the inner tire rod or the axle bearing i came up only with these two because i have a bad inner tire rod and a bad axle bearing and i know one of those are making a noise something better than nothing:monkey:
