You could always fill the ones you have with that 3m window weld stuff (search to find out details).
Otherwise, I know place racing used to make mounts for the p10 (I have them and love them) but I'm not sure about aftermarket for the p11 other than Pat's (Yahnozha) crossmember mounts, but he only makes two of them I believe. Search for answers with that too.
3m works
yes, i have personally used this stuff, just fill your motor mounts with the stuff, make sure you clean your motor mounts with alcohol or paint thinner first to remove all the grease, do not use engine degreaser... you will feel more vibration when your done but it will be solid as hell and will never tear again!!!!
vsamoylov said:
I know I can always get OEM mounts but any other options out there for a p11 g20? thanks
if you like the stock ride feel as it is, you need to get new OEM mounts. Filling mounts will increase noise, vibration, and harshness. There are tons of threads on this, search it up :teeth:
