1 - 2 of 2 Posts
Hey guys, another quick question, i was, well i still am getting a wheel bearing noise from my P11 Primera front. It sounded like it was coming from the left front wheel, so i changed that. Bearing noise got quieter. But i still hearing a bearing noise. What could it be? It is not the right one for sure (bearing).
make sure it was installed properly, if its the same as the p10 it needs to be pressed in, the human eye can not gauge a properly set bearing, if you did it yourself it might have been the way you set it, you can not do a little at a time side to side, it must be properly pressed in, anyways i hope you get it resolved, i had the same problem before but once i took it to a manchine shop to install it correctly, it was as smoth as a hot knife going into butter.. good luck
1 - 2 of 2 Posts
