I was trying to find where the ECU is on a P11, I remember a thread for a P10 ECU, is it in the same place (pass. side?)
A pic would would be helpful if you've got it.
I am pretty sure that the ECU is located right under the center dash section. Sorta like behind and under the ashtray area. If you're looking to reset it, i think the reset screw is on the passenger side, however I'm not 100% sure if that holds true for a P11, I know that's how it is for the P10 and I'm pretty sure it's the same on both.
what would you have to reset it for if you don't mind me asking??
here's a couple reason's why...
NismoPC said:
Usually when you modify the car in such a way that it effects air flow, exhaust, air/fuel mixture, timing, etc. Just allows the ECU to re-learn the changes and acknowledge the changing.
Just good practice when installing an intake, header, exhaust, cams, advancing the timing, etc.
g20t94 said:
I was able to resolved my engine light freakin' problem by resetting my ECU. I thought I had to replace my EGR valve. Before you go into conclusion that it was your EGR or any possible problems, make sure to try resetting your ECU first.
I installed new spark plugs, and didnt push all the way on one of them, after I resolved that problem, the check eng. light came on. I installed new plugs, and the light is still on, so I need to reset my ECU.
I need a pic please!
Where on the driver's side? Does anyone have a pic??
