i have a 94 g20. its had check engine light on since i got it with codes for EGR valve, knock sensor and o2 sensor. loud exhaust as well. so it runs a little rough but still gets me around. pulling onto the highway it didnt want to rev up so i floored it and when it finally let loose there was a bunch of white smoke coming out the back. i cautiously drove it while while watching the heat gauge to try and get to a parts store. it heated up but i stopped before it got to the max line. when i opened the hood i saw the radiator hose just hanging there unconnected. when i reconnected it the housing was cracked. rigged it up to attach further up and now it still drives about like it did before but i havent driven it far.
so i few ppl have said blown head gasket. i checked the compression on it today and i got 171, 171, 176, 176. the white smoke was bad right at first but then it went down to a little and now i dont notice any.
anything else that could be wrong other than engine block or head gasket? is there a test i can do to make sure its safe to drive??
thanks
thanks
